PXI
Myrio Remote Front panel Control
I am working on an academic project. I am using myRIO 1900. i want to access my front panel remotely on web. I have followed
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7YuSAK&l=de-DE
http://zone.ni.com/reference/en-XX/help/370622R-01/lvrthowto/remotepanels_rt_target/
links.
But, when I try to access on web I encounter error shown in browser.jgp file.
some other pictures are also attached.
If some one understand whats going wrong, Please figure out.
If there is any example for myRIO front panel remote access please share. Thank
(2,590 Views)
Hi Ahsan, I believe you are taking correct steps.
I want to see what error are you encountering. Would you mind attaching "browser.jpg"?
Certified LabVIEW Developer
GCentral
(2,561 Views)
HI Emboar,
browser.jpg is attached here.
Also, I want to ask "Do mtRIO needs wifi Conection". if "yes" Which IP adress I should use.
IP Adress when Conneted through USB is 172.22.11.2 and when Connected over Wifi IP adress is Something like shown in "image.png" .
(2,559 Views)
You want to have a connection via Wifi but it looks that the connection is established via 172.11.22.1.
The IP is used on USB over Ethernet, not Wifi.
I believe myRIO on your LabVIEW project is set to "172.11.22.1".
Why don't you change it to "172.16.21.217" and try it again.
GCentral
(2,533 Views)
Hello.
I have a similar problem. But I managed to connect to the RT device using the "connect to remote panel" function in Labview and also in Labview Run-time. But when I try to connect using the IE browser, I get a 404 error.   http://192.168.0.101:8080/Main.html
Meantime i can easily connect to file browser of my RT device (myRIO-1900) via https  https://192.168.0.101/files/ .and when i browse to html file manual i will recieve next error (ERROR.PNG)
HTTP port 8080.
(2,376 Views)
