We have a PXIe-1078 connected to a computer through a PXIe-8360 and PXIe-8361. After a recent power outage, the system has developed the following issue.
The unit appears to power on (power button on PXIe-1078 turns green, pwr light on PXIe-8360 turns solid green, fans turn on), but as soon as the computer is turned on the pwr light on the PXIe-8360 turns briefly red, then the chassis powers off. The chassis does not power on after the computer is turned on.
We have tried using a different computer with a different PXIe-8361 installed and replacing the PXIe-8360, but the problem persists.
Has anyone else observed a similar issue, and if so, is there a resolution?
Thank you
