PXI
PXIe-5654 multi-module synchronization
What is the synchronization capabilities of the 5654 CW modules?  From the block diagram, it looks like they won't be able to share an LO but it does look like the reference can be shared.  So...
1. Can the modules be phase-synchronous at an RF output level?
2. Can the modules be time synchronous and start on the same trigger level and use the same reference?
3. The phase noise looks great.  What is the phase stability over time?
Thanks!
Message 1 of 1
(3,259 Views)
