PXI
Programming PXI SMUs using LabWindows/CVI
I have a PXIe-1083 chassis with 4 PXI-2535 switch matrix cards and one PXIe-4141 card installed. I am new to PXI system so I started from PXIe-4141 examples.
I was able to compile and run NI-DCPower Source DC Current example. But when I try to read the code, there are functions that I couldn't find any documentation.
niModInstCVICust_NewCtrl()
niModInstCVICust_DiscardCtrl()
I also have problems finding documentations and command sets on how to program those switch matrix and smus. Really appreciate if somebody can give me some advices!
Yimin
(1,499 Views)
Accepted by topic author AmyJing
Yimin,
I am assuming by the mention of niModInstCVICust_NewCtrl() that you are using CVI.
The niModInstCVICust_*Ctrl() functions are pseudo-private entry points which allow for automatic population of the Resource Name drop-down control while the CVI example is running. It is a usability feature NI provides for products which support NI-ModInst.
What version of NI-DCPower and NI-SWITCH do you have installed?
I would recommend looking at the NI-SWITCH CVI examples as well, particularly "Handshaking with an NI-DMM".
Both NI-DCPower and NI-SWITCH install help files, including sections where you can learn about the various API functions. They are also available on ni.com. Here is NI-DCPower's and NI-SWITCH's.
Tobias
Principal Software Engineer
Driver Software
(1,440 Views)
Hi Tobias,
Thank you so much for your reply!
Yes, I am using LabWindow/CVI 2017 for developing language. The drivers' version I installed as following. Are those the right version?
NI-Switch: 22.8.0.49363
NI-DCPower: 22.8.0.49662
Thanks a lot for the links!
Yimin
(1,419 Views)
Yes, those are the drivers you need for these instruments, and those versions are perfectly fine. It wouldn't hurt to upgrade to the very latest, though.
Tobias
Driver Software
(1,409 Views)
Thank you so much, Tobias!
(1,398 Views)
