11-14-2022 07:11 AM
I am planning to use usb6255 and two scb68A together in my project, Can anyone please advise what kind of cable(cable part number) should be used to connect them ? Thanks!
Solved! Go to Solution.
11-14-2022 09:11 AM
Here is a list of supported accessories.
11-14-2022 12:47 PM
Thank you ! Santo
so I can use SH68-68-EPM cable for one scb 68A, and SH68-68-S cable for the second scb 68A, correct?
11-14-2022 01:01 PM
Yes, that is correct.
The same information is available in M-Series user manual pg#30
11-14-2022 01:17 PM
oh, it is SC68-68-EPM and SHC68-68 for scb-68A. not SH68-68-EPM and SH68-68-s, they are different.
11-14-2022 02:44 PM
Above are different cable information for USB6255, begin with SC and SH, SHC, which one is correct one ? or they are same? Thanks!
11-14-2022 04:23 PM
This document explains all about cables - https://www.ni.com/en-us/support/documentation/supplemental/17/main-page---daq-multifunction-i-o-cab...
11-15-2022 06:44 AM
Thank you very much for your help! Santo
11-16-2022 09:37 AM
Hi Santo,
when I order USB6255, do I need order AC adaptor and usb cable which connect usb6255 to computer? or both are included in USB6255 order package? if require separate order, can you please advise the part number for both? Thanks!
11-16-2022 04:52 PM
@wwn wrote:
Hi Santo,
I am not sure about that, since it did not recommend a USB cable or power adapter while placing an order I would assume that those come with the USB-6255.
