PXI
Upgrading PXI-8108 from XP to Windows 7
Are there any issues in upgrading our PXI-8108 embedded controller from XP to Windows 7 that is dfferent from a regular PC?  Any gotchas. hints, or suggestions?
Message 1 of 11
(8,418 Views)
Hi John,
Upgrading the OS on a PXI controller is the same as any other computer. You will have to manually install all NI software and drivers, but otherwise, it has common drivers that windows 7 should be able to find as long as you are connected to the internet.
Trevor B.
PSE
Message 2 of 11
(8,403 Views)
Thanks!
I thought as much but I wanted to be informed.   I assume it supports 64 bit too?  Any issues with 64 bit?
Message 3 of 11
(8,398 Views)
Aside from the standard issues with driver support for specific NI products, I expect that the PXI-8108 can support 64-bit Windows. You would just need to get the correct peripheral drivers.
Gabriel M.
Product Marketing Engineer - Academic Courseware
Message 4 of 11
(8,381 Views)
Hi Guys,
Can i get the PXI 8108 peripheral driver in the NI website?
Message 5 of 11
(7,191 Views)
Moved to new thread:
http://forums.ni.com/t5/PXI/PXI-8108-and-Win7-64-bit/m-p/3069360/highlight/false#M14336
David R
Systems Engineer
Message 6 of 11
(7,184 Views)
I have a new NI PXI-8108. I'm not sure what OS is included in it; however, I want to have Windows 7 installed on it once I install the controller to the chassis. If I want to upgrade how will I be able to do so?
Message 7 of 11
(6,705 Views)
Message 8 of 11
(6,701 Views)
It works fine.   There are number of ways to get Window 7
1.  Use a portable USB DVD player.  Make it bootable from USB in BIOS.
2.  Mount and share another computer's DVD drive and use that.  But it doesn't work for booting.  However I don't think it is still necessary to boot.   I think you can run the setup file.    The downside to this approach is that your registry will have mappings to the network drive which may not always exist and create delays as your computer tries to ping them.
3.  Use various imaging tools like Norton Ghost or Clonzilla to put a predefined image.
There are more ways too like mounting and booting from an ISO image located on a USB external drive.  You need some software for this but there are some free ones out there that work.
Often your IT group has ways of provisioning a machine over the network.
Message 9 of 11
(6,698 Views)
I also cloned the HDD and replaced it with a much larger SSD.  A total WOW performance upgrade
Message 10 of 11
(4,280 Views)
