PXI
rt8145 set date
I have PXI8145RT and Labview 7. After years of use, the system lost its system date. I have replaced the on-board battery (time keeper) but still when the get date/time function is invoked I get the value 1/1/1980. How can this be fixed ? Is there any way to programatically reset the correct date/time
Thanks for the help
(3,475 Views)
Hi kpapad66,
Have you seen this KnowledgeBase article for correcting the time on an RT controller?
The Current Time is Incorrect on My LabVIEW Real-Time Controller
http://digital.ni.com/public.nsf/allkb/E9D08C9F795FF49F86256F9000040DC9
It also looks like you on an RT controller, you can boot into the BIOS to correct the date and time.
How does Real-Time Hardware Update Its System Clock?
http://digital.ni.com/public.nsf/allkb/9DCFB7C0EB06CA9786257440006182E2
Jake H
(3,453 Views)
Thanks for the reply. The straightforward way to correct the date\time settings is to do it from the RT palette VIs.
(3,390 Views)
