03-06-2020 12:56 PM
I have ended up with a 5644R VST I have never used. So I don't know a lot about its capabilities. And I have never used the FPGA toolkit.
I want to use the VST in a test set that has an Agilent E4433 generator right now. I need to modulate the 5644R (BFSK) with the BERT output. It looks like I should be able to do that, but before I start chasing it down and potentially wasting a lot of time, can somebody tell me if its's possible, and give me a pointer towards how to do it?
I've searched the site but can't find a straight answer to this question.
03-06-2020 01:10 PM
Have you configured your PC with the tools and drivers that the 5644 needs?
For example to have the 5644 run as a generator you need NI RFSG https://www.ni.com/en-us/support/downloads/drivers/download.ni-rfsg.html#333282 (see readme: https://www.ni.com/pdf/manuals/374769w.html)
Not trying to talk you out the E4433, but what is the reason for going from the 4433 to 5644?
03-06-2020 01:44 PM
The chassis is on a bottom shelf right now. As I recall, I had all the goods installed (RFSG, RFSA, VST Toolkit, FPGA something-or-other). But I will get it out and see what's there. If it all is there, will the answer be right in front of me?
Why?
1: It's a fewer-box solution and I can clear some space
2: The 4433 gets freed up for other things
3: I would like to use the 5644 because it's just sitting there otherwise and that's a shame
4: I get to learn more LabVIEW
5: It's way cooler
03-10-2020 03:21 PM
I suggest confirming that you can run the generator and analyzer examples (See LabVIEW's example finder) and via instrument studio (used to be the soft front panels).
03-25-2020 08:17 AM
OK, I got out the VST and booted it up. Installed is:
NOT installed is the FPGA module. I believe this VST was bought for WLAN only and didn't need the FPGA.
I am going to assume that to do this modulation via hardware I need the FPGA module. I see from the help file there are FPGA resources that include IQ inputs.
Any advice on what to do next?
03-25-2020 10:39 AM
How are you using the E4433 now? Do you have a waveform file that you're downloading? Is it's output being modulated by another analog signal?
03-25-2020 11:11 AM
The 4433 is modulated by an external bit error rate tester. It is set up to use the BNCs on the front panel for clock and data to modulate a BFSK signal with specified deviation. I want to modulate the 5644 in the same way.
The BERT is an old TTC Fireberd 6000A with TTL output. This is the easiest way of implementing a bit error rate test, by using the Fireberd. It's a purpose-built machine that just does it. I suppose it would be possible to create vis to modulate the 5644 and then bring the recovered bistream back into the FPGA, and figure out a way to correlate the waveforms. Too much work, I just want to modulate the 5644 with the external source and let the Fireberd do all the work.
So the bottom-line question is, how do I modulate the 5644 with an external signal. Is it even possible?
03-25-2020 12:28 PM
The newest version I would recommend is LabVIEW 2015. After that version NI no longer makes the FPGA code available online.
See the download link: https://www.ni.com/en-us/support/downloads/drivers/download.vst-instrument-design-libraries.html#331...
03-25-2020 03:15 PM
OK - but, if I can't do this modulation using an outside piece of hardware, there's no reason for me to do anything else on this chassis. Can you tell me if it's possible?
I honestly can't tell from any of the literature.
03-25-2020 03:24 PM
You could write something to do it so long as the hardware output supports it.
