FIFO.config -61206: but the name of FIFO exists
Hallo,
I'm relative new to cRIO and I became an error from last time I compiled my FPGA.
HW Description
  • cRIO-9035
  • 4 x NI9229
Software Description
  • FPGA: I have 15 DMA FIFO (I can make this according to this document), that send asynchronous messages on each FIFO   (show attached Picture)
  • RT: I catch this messages and I store them in a TDMS file
Problem
  • FIFO.Configure or FIFO.start give me "Error -61206". This Error, as shown here, means that the name of this FIFO doesn't exists. But as shown in picture it exists. I don't know what's happened. Is the first time that I become an error like this.
For your kindful help, I will say you "Grazie!"
Carmine
(3,741 Views)
Accepted by topic author cderrico
I found the problem.
Only the FIFOs really used on FPGA can be configured.
If you declare a FIFO and you will not use it on FPGA (for example in order to make a test of only a part of your project) you have to remove from RT code the parts where you configures, starts ancd closes the FIFO.
Thank your for your attention.
Carmine
(3,731 Views)
