11-14-2007 02:11 PM
11-15-2007 06:00 PM
11-21-2007 08:13 AM
Hi Yi Y,
I'm having the same problem posted here. I appreciate very much if you could explain me better how can I get the "coefficent acquired based DELTA V". This value must be multiply every loop, mustn't it? Don't you have a example (VI)?
Thank you very much!
Paulo Paraizo.
11-26-2007 08:54 PM
This will take a snapshot of what the shunt calibration and offset calibration under no load are and store these correcting values to the EEPROM. Then, when you take measurements in future programs (like in the getting started example), these values will be applied automatically.
As for what resistance to select for, see this KnowledgeBase article.
Craig D
11-27-2007 04:02 AM
Hi Grag, Thank you very much!
Just one more question! Can I put these 2 frames starting my FPGA VI? By this way, I suppose running the VI, it'll calibrate every time, won't it?
Once more, tk's!
Paulo.
11-27-2007 09:33 AM
Paulo,
If your VI will start with your strain gauge in an unloaded state, then yes, you can put these frames at the start of your VI. As you may suspect, if the strain gauge is loaded when you enable null offset, it will equate that load point to be zero.
Craig D
11-28-2007 12:18 PM - edited 11-28-2007 12:23 PM
11-29-2007 02:40 PM
12-02-2007 11:09 PM
12-05-2007 12:06 PM - edited 12-05-2007 12:08 PM
