How do I set strain gauge resistance on 9237
Does any body know how to find this file http://www.ni.com/pdf/manuals/374186b.pdf
Yi Y wrote:
Hi Rex1030,
You can find more information regarding shunt calibration and strain guage resistance in the manual http://www.ni.com/pdf/manuals/374186b.pdf, please go through page 10-14.  More information about the calibration procedure can be found here. http://www.ni.com/pdf/manuals/372251a.pdf The strain gauge resistance is set by using the known resistance value during calibration. Hope this helps!
Yi Y.
http://www.ni.com/support
Message 61 of 67
(1,731 Views)
It appears the version has bumped, try
http://www.ni.com/pdf/manuals/374186c.pdf
Message 62 of 67
(1,702 Views)
Thank you!
Message 63 of 67
(1,687 Views)
I have to find out the strain in a motor stand where i will be attaching a student gauge ( gauge factor 2.1) . The DAQ system that i will be using is a  NI PXI-1042Q and the strain module is NI 9237. I have also decided to go for a full bridge connection. but, I need a help in the following topics.
1) procedure for Calibration ( shunt or by adding weights)  - which one is easy and good
2)Getting out the values through LABVIEW code
Pl, help me ASAP. I am trying my best to find out but there isn't enough time. Awaitng fr ur kind replies.
Message 64 of 67
(949 Views)
Abautomitive,
Thank you for using the forums.  It sounds like you want to create a custom scale.  With this you can map output voltages to a known strain or force.  You can create a custom scale by following this knowledgebase article.  The way that you can input this and read the values out of LabVIEW is by dragging the custom scale into your LabVIEW code and connect it as shown in this example.  Another way you can create a custom scale, is in the DAQ Assistant, go to Scale and choose custom scale.
I hope this helps,
Brian P.
Message 65 of 67
(936 Views)
I am having a 58BA Shaft Encoder ( rotary incremental shaft encoder) and a NI SCB 68 .The NI SCB 68 is a connector block which allows digital inputs and outputs to and from the PXI 7813R DIO Card. This will be used to connect the shaft encoder wires to the datalogging equipment.
Please clarify my following doubts:
1) How to wire the Shaft encoder to the NI SCB 68
2) How to get the values from the shaft encoder. Please send me some examples if u have got it.
Thanks in advance. Awaiting your response.
Message 66 of 67
(931 Views)
Thanks brian,
I will go through it and will come up with a query, if i encounter one............ thanks for your help.
Message 67 of 67
(930 Views)
