Web Service (RESTful) on RT-Target
I'm trying to communicate with a VI on a real-time target using the RESTful web service (set parameter for In-ports and get Out-Ports via xml). I created a built-spec which I can also built. But if I try to deploy it, I get a conflict error. The message just tells, that web service deploy failed. I tried several different configurations for the web server, but didn't succeed.
Communication via Remote-Front-Panel works fine. I'm using LV 2010 (evaluation).
Any ideas? Where can I get more details about the error? Are there any logs?
Frank
(3,442 Views)
Hi Frank,
do you have an error code or can you post a screenshot with that error message?
You can try to look at ni.com for the error code.
Stefan
(3,419 Views)
