Xilinx compile server error not configured incorrectly
Hi
was using NI LabVIEW 2015 SP1 (32-bit) to compile rs232 application on cRio 9082 , every thing was fine and compilation was always suucessful via local compiler.
recently i got compile error message saying local compiler was not configured correctly , and i review compiler configuration found it Xilinx 64 bit not 32 bit like my installed NI LabVIEW 2015 SP1 (32-bit) , refere to attached screen shoots
Please advice how i might fix the issue ,
MyKat
(3,201 Views)
Hi MyKat,
To use cRIO-9082 with LabVIEW 2015 SP1, you need ISE 14.7, which seems like you already have judging from the first screencap.
The second screen cap shows you are trying to compile a bitfile for a cRIO-9104 chassis, which requires ISE 10.1 and can be downloaded from here.
Please double check which FPGA target you are using.
Ren H.
Applications Engineering
(3,162 Views)
