[cRIO] WEB CONFIGURATION ERROR
HELP ME!!
Dear all,
When I try to test an app with web server, I configured some setting in Web Configuration from NI-MAX.
At first, the address is : http://169.254.4.42/bla bla...
But after my setting, I change to localhost (as picture below) and the Web Configuration in NI-MAX also be disabled.
Please help me how to fix it!
(3,676 Views)
Hi d4nvjpl0ng4n,
You mentioned that you changed a setting at some point; what setting did you change? I’ve used the two links posted below to walk through the process myself, and cannot recreate what you are seeing in your second image.
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/ni_webconfig/
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/ws_enable_web_server/
Ross S.
Applications Engineering
(3,643 Views)
I have already fixed it by formatting the cRIO and reset all setting to default. Thank you so much
(3,610 Views)
Glad to hear it! Best of luck with your future projects.
Ross S.
(3,597 Views)
