08-21-2015 02:22 PM
I have (4) SCXI-1520 modules, used to measure bridge type sensors. While tesing them with a Fluke 753 Process calibrator, the two older modules 186338D-01 exhibit high noise (AC 60Hz). The injected signal is 100 mVdc and the Fluke 753 is on battery power. The AC noise is 4 mVac non-sinusoidal. The other two SCXI-1520 modules are noise free using the same chassis and setup.
08-24-2015 07:26 PM
Hi eroberts@water.ca.gov,
Could you tell us more about your hardware configuration? Such as:
08-25-2015 08:44 AM
Hi Briana,
We have (2) SCXI-1000 chassis, (2) SCXI-1314 connector blocks. The connector blocks have 3 feet of Belden 8723 signal cables installed on each channel. The cables are terminated with MIL-C connectors.
The modules that fail exhibit noise on all channels. They have been swapped into various chassis and terminal blocks and fail in any position.
08-26-2015 06:20 PM
Thanks for the information. You mentioned that the two older modules were the ones experiencing noise. When is the last time the modules were calibrated?
