How to measure high voltage AC (upto120 V) and acquire the output in LAB View, which equipment or devices to use. It would be preferable if i can get sampled instantaneous values to reconstruct the waveform in LAB View for analysis.
Working on a project to monitor distribution transformer, need to convert the current and voltage output given by current and voltage transformers for measurement which is in range of 5 amps. and 120 volts resp.
If the range is not directly available, did you consider using a simple voltage divider circuit to reduce the voltage into a range that can be sampled?
