Signal Conditioning
mV/psi input for SCXI-1102 using SCXI-1308?
Is there a way to physically connect a mV/psi signal to an SCXI-1102 that is also using a SCXI-1308 terminal block? From what I have read, the terminal block can only use a 4-20 or 0-20mA signal, right? I don't see any pins that the terminal block doesn't plug in to to use for the pressure sensor's mV output.
Thank you for the help!
tq
(6,028 Views)
Accepted by topic author FMC_Pumptest
Hi FMC_Pumptest,
The 1308 terminal block is designed for current input. You are right that with that terminal block you will only have inputs for 0-20 mA and 4-20 mA signals.
James D.
(6,009 Views)
