Software Defined Radio
USRP Bus series B205-mini
Hello
I am using B205-mini in embedded applications. The issue i am facing is that each time the device is powered on it starts loading the firmware and the FPGA bitstream. This process takes about 5 to 6 minutes. I wanted to permanently burn all the firmware so that i can reduce the boot time.
Looking for some guidance.
