Sound and Vibration
Getting Started with Modal Analysis in LV
The folder here contains a VI palette that gives you the basic building blocks for Modal Anlaysis.
Several pieces of NI software need to be installed before you download this palette. They are:
LabVIEW 2009 or later.
Sound and Vibration Measurement Suite 2009 or later
System Identification Toolkit 9.0 and later
Installation Instructions
1) Exit out of LabVIEW if you have it open. If it is already closed do not open it.
2) Download the Modal Analysis folder and save it in your user.lib folder for LabVIEW. The image below shows what it might look like on your machine.
3) Close the user.lib directory and start LabVIEW.
The VI pallette should be in your User Libraries. The following image highlights what it should look like.
Message 1 of 12
(31,757 Views)
I am not able to do the modal parameter extraction from the FRF data.Please help me out.
Message 2 of 12
(21,461 Views)
Greetings pswalunj!  We'd be glad to further assist you, however this isn't the best medium to do so.  Please either contact your NI local support or post to our discussion forums, and someone will be glad to help out.  Feel free to reference back to this example, and further detail what problem(s) you're running into.  Thanks!
Paul Davidson
Product Owner - ni.com Chat
Message 3 of 12
(21,462 Views)
Ok. Thanks sir for your Quick and positive response.
Prashant Walunj.
Message 4 of 12
(21,462 Views)
I am unable to read FRF magnitude,phase and coherence graphs and predict about natural frequencies, need guidance.
Message 5 of 12
(21,462 Views)
Hi, 411051
We don't have much monitoring of this space for answering your questions. I would recommend posting to the discussion forumns.
http://forums.ni.com/t5/Dynamic-Signal-Acquisition/bd-p/100
I believe you will get a better response from that forumn.
Message 6 of 12
(21,462 Views)
Hi, I run the examples in this module and it seem good. But there is no example using MP_SSI VIs. Could you please send me some example using that VI? Thank you!
Message 7 of 12
(20,489 Views)
Hi, is there a way to save the modal animation as a video? Thanks.
Message 8 of 12
(20,343 Views)
I do it as you show, but my platte shows something as follow. please help me. thank you.
Message 9 of 12
(16,587 Views)
Hi~
  it is not able to start the Modal analysis.vi, because the program lacks the  si_Estimate Model_input FRF format adjustment (SISO).vi.
I am appreciated to hope you to supplement the SISO.vi.    Thank you very much.
Message 10 of 12
(13,545 Views)
