I want to share this series of resources in which you can see projects integrating LabVIEW, a DAQ or an embedded system like a Raspberry, explore practical tips to improve the quality of your code when developing systems that are scalable over time and easy to maintain.
Data logging with a USB data acquisition device
Using LabVIEW and a USB data acquisition device, you can build a data logger to acquire, record, and save signal data. In this video, you will learn how to customize the log file settings and how to save the data as different file types, such as TXT or Technical Data Management Stream (TDMS), either by creating new files or by overwriting or appending existing files. Additionally, you will see how to open and view log files in LabVIEW natively or in Microsoft Excel using the TDMS plugin included with LabVIEW.
Generating a signal with your computer
Learn how to use the USB data acquisition device to create signal builds in LabVIEW. In this video, you will see how to use LabVIEW VIs to customize and generate output values such as voltage or waveforms from a USB data acquisition device. You will also learn how to implement a front panel slider and stop button to control the output.https://www.ni.com/es-cr/shop/data-acquisition-and-control/what-are-multifunction-io-devices/generat...
Raspberry Pi disassembly using VirtualBench
This webcast shows debugging a Raspberry Pi. Explore AC, DC, and digital signals using the single interface of a VirtualBench instrument.https://www.ni.com/es-cr/shop/electronic-test-instrumentation/virtualbench/what-is-virtualbench/rasp...
