Sync Labs
Error code -52010 from NI-TimeSync Plugins property node
I am using LV2012 with RIO 12.0 on a cRIO-9025 controller. I used the NI-MAX utility to custom install "NI-TimeSync 1.2.0", "NI-TimeSync Custom Time Reference 1.2.0", "NI-TimeSync Plugin for SNTP 1.2.0", and "NI-TimeSync Plugin for Software-Based 1588 1.2.0".
I have used the TimeSync utility on various cRIO controllers without difficulty, but I have another cRIO controller that I am upgrading, and am observing Error -52010 coming out of the NI-TimeSync Plugins property node. The property node is configured to read "SNTP Server IP Address", "Synchronization Threshold", and "Sync Interval".
Any thoughts on how to avoid this error code?
Thank you for any assistance you can offer.
(6,378 Views)
Nevermind, the error is a result of not setting source.sntp.address in /ni-rt/system/ni-timesync/nitimesync-sntp.ini.
(4,920 Views)
