Troubleshooting Hardware
NI roboRio v1 not connecting to laptop.
Hi all, we have been attempting to connect our NI roboRio v1 to our HP laptop running WPIlib in preparation for the FIRST competition. The connection method is between our computer and the Open-Mesh OM5P-AC FIRST Robotics Competition Robot Radio, which is connected to the roboRio and a Limelight camera via ethernet cables. When we power the roboRIO with a fully charged battery transferring the correct voltage, the system turns on but does not connect to the computer. We know the issue is not with the Open-Mesh radio module because we have used the same one in other systems which connects to the laptop without issue. The problem is with this specific roboRio because the system connects when we use another roboRio of the same make and model in the same system. We were hoping to get the problematic roboRio replaced. Thank you!
(69 Views)
Hi Ari-691
When the device is connected, does it show any blinking pattern?
Can you ping the roborio using mDNS? or can you ping the roboRIO IP address? Please follow these steps and let me know if you have any update
(26 Views)
