Troubleshooting Hardware
Robo Rio 1 - Bad Network Jack
RoboRio P/N: 155213F-01L
S/N: 30FC9E8
Network Jack does not keep a consistent connection. Pins are clean, appears solder joints may be cracked. Slight movement of any cable inside connector causes loss of connection. During testing and diagnostics the jack/NIC doesn't even come up a majority of the time.
USB network connection works.
(277 Views)
I'd like to get an RMA started if at all possible!!. Thanks!!!
(242 Views)
Hi mortobot,
Thanks for sharing this information!
I have contacted you privately for further steps.
Thanks!
(208 Views)
