UI Interest Group Discussions
Custom Control - 3 poll switch instead of 2 poll
I'm sure that others have wanted to do this, and it has probably been done many times before.  I'm hoping someone can help me.  The default boolean control for a switch on the pallette is a 2 pole switch (which makes sense for a boolean terminal).  I'm needing my GUI to represent a 3 pole switch with knob positions up, middle, and down.  I'm guessing that this can be done by creating a custom control slide rule with 3 positions (0, 1, 2), but I haven't figured out how to make the slider change pictures from one state to another and the slider moves up and down.
Anyway, I like the way the switch looks but need 3 positions.  Any guidance on where I can look or help?
-Dan
(6,806 Views)
Use a knob or a dial, as an integer number.
Customize it to hide the the numbers, lines, etc.
(3,026 Views)
yes, it's already been done:
http://forums.ni.com/t5/LabVIEW/3-way-vertical-toggle-switch/m-p/219368
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,026 Views)
