UI Interest Group Discussions
Dock windows system in LabView
Our ALOHA framework supports windows that can float or "dock" into a container window. It is a free framework. You can check it out at http://www.seneca5.com/aloha.html.
Each of the VI's run as a separate Agent. The framework can doc them into a parent window by using subpanels. A VI can be inserted/removed from a sub-panel any time you want, even if it is running. ALOHA manages all that for you. Or you can dive down into our code to see how it was done.
Message 11 of 12
(2,681 Views)
I made a C# control to load a .net docking library to use inside a Labview .Net control. See example https://decibel.ni.com/content/docs/DOC-46494
Message 12 of 12
(2,681 Views)
