UKTAG – UK Test Automation Group
Pluggin' into Switch Executive
Does anybody have some hints on how to plug in to SwitchExecutive to integrate an own (non-NI based) switching device? In my  case, I am thinking about integrating a pneumatic switching matrix with 72 valves...
If it is possble at all....
Cheers
Oli
(3,986 Views)
Accepted by Oli_Wachno
I never tried that but I've read that with IVI Switch driver you should be able to accomplish this (or at least that what I understand). So, you need custom IVI Switch Driver.
Check this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x12BCAQ&l=pl-PL
And this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1s7CAA&l=pl-PL
Michał Bieńkowski
CLA, CTA, CPI
(3,979 Views)
Adding to Michal's links, I have managed to use it with pickering devices. You need to make it IVI compaitble.
Link: https://www.pickeringtest.com/kb/software-topics/using-pickering-switches-in-various-programming-lan...
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,974 Views)
@Michal
@Sree
thanks for the information, it'a a good starting point! The only thing, which bothers me a bit is that I was not yet able to find a .net template for a IVI switch driver. CVI is not part of our regular toolchain, so I am a bit reluctant.
I shall keep on searching. As of now, we're evaluating the feasibilty of this concept in general.
Cheers
Oli
(3,936 Views)
Hello Oli,
See also:
Using IVI Drivers with LabView
https://www.ivifoundation.org/downloads/IVI%20short%20guides%202015/Using%20IVI%20with%20LabVIEW.pdf
Writing IVI driver with LabWindows/CVI
https://www.testandmeasurement.com/doc/writing-an-ivi-driver-0001
Seems that LabWindows is first choice...
BR
Eugen Wiebe
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,934 Views)
I'm not the expert but look for ".NET IviSwtch"
https://www.ivifoundation.org/downloads/Class%20Specifications/IVI-4.6_Swtch_2011-08-25.pdf
There is .NET IVI as well.
Michał Bieńkowski
CLA, CTA, CPI
(3,932 Views)
