06-09-2014 07:57 PM
I'm new to the RF field and am having trouble getting my USRP set up to work with gnuradio. I'm currently running a Ubuntu 14.04 virtual box. I have gnuradio already up and running. I installed the linux UHD binary from: http://ettus-apps.sourcerepo.com/redmine/ettus/projects/uhd/wiki/UHD_Linux. However, it gave me an error and said something already already existed in a different package. I managed to successfully install it though i believe. So i tried to do 'Building an fm receiver' :http://www.youtube.com/watch?v=KWeY2yqwVA0. This is what i get when I execute:
Using Volk machine: ssse3_64_orc
Traceback (most recent call last):
File "/home/william/Desktop/fm_example.py", line 156, in <module>
tb = fm_example()
File "/home/william/Desktop/fm_example.py", line 91, in __init__
channels=range(1),
File "/usr/lib/python2.7/dist-packages/gnuradio/uhd/__init__.py", line 122, in constructor_interceptor
return old_constructor(*args)
File "/usr/lib/python2.7/dist-packages/gnuradio/uhd/uhd_swig.py", line 1735, in make
return _uhd_swig.usrp_source_make(*args)
RuntimeError: LookupError: KeyError: No devices found for ----->
Empty Device Address
I know this is something to do with UHD but I don't know where I'm going wrong. The device (USRP) is correctly identified by the virtual box, so I know there is a connection established. Any suggestions would be great! Thanks!
06-10-2014 03:39 PM
wdwoodwa,
We recommend checking out the GNURadio and USRP mailings lists for GNURadio and UHD questions. This board here focuses on support of USRPs with LabVIEW and the NI-USRP driver.
http://gnuradio.org/redmine/projects/gnuradio/wiki/MailingLists
