12-01-2014 09:51 AM
12-02-2014 05:07 PM
Hi AdeelAnwar,
What version of NI-USRP are you using, and how are you connecting your signal to the USRP-RIO?
What VI are you opening within the USRP Streaming project - and where are you modifying the trigger to be an external trigger?
Thanks!
12-02-2014 08:05 PM
12-03-2014 03:11 PM
Hi Adeel,
I'm having trouble finding the exact VI you're using and settings you're changing. In order to create a USRP RIO sample streaming project, I load LabVIEW, select "Create Project", select "NI-USRP" in the left pane, and open the "Simple NI-USRP Streaming" example.
I then have this project window:
Is your project similar? And if so, which VI are you changing your settings in?
12-03-2014 10:08 PM
Hi Rick,
I am using "Rx Streaming (Host)" vi. with the settings shown in figure below. Sampling-rate is 3.125 MSPS and num-samples=1040.
I have also attached the figure of "Start-Trigger" which is a subVI of "Streaming XCVR FPGA", where AUX I/O-0 is acts as the source of trigger when we select "Digital-Edge" in the Host VI.
Adeel
12-05-2014 09:20 AM
Hi Adeel,
I was able to find the settings - thanks for those images!. Now let's talk about the two issues you were having:
1: The RF pulse is not exactely at 1st sample and the initial delay varies randomly at differnt runs of program. But during a single run, the delay remains constant.
When you say "not exactly" at the first sample, do you mean that you receive multiple digital edges before acquisition begins, or there's a delay from the rising edge of the trigger? For the delay that you're seeing, how much of a delay, in general, do you see?
2: Sometimes the RF pulse starts running on graph showing that data is not not acquired properly based on trigger edge.
Could you elaborate on this? Perhaps some images of what you're trying to describe could be helpful as well.
Thanks.
12-09-2014 07:04 AM
12-09-2014 07:18 AM
12-09-2014 07:22 AM
12-09-2014 07:46 AM
