02-13-2020 11:26 PM
06-09-2021 02:24 AM
The retune time is dependent on how far to tune. Within 100 MHz and the retuning time is ~1.5 ms. Beyond 100 MHz, it is ~170 ms due to the DC offset calibration. It is possible to extend the range beyond 100 MHz, but the DC offset and IQ imbalance will get worse the larger the range is made.
The UHD 3.9.1 retune times were ~3.3 ms within 100 MHz and ~205 ms beyond 100 MHz. Your sample rate can be lower, but setting the master clock rate higher gives you more room to tune the DSP frequency without changing the LO frequency. At a master clock rate of 30.72, you will have a DSP tuning range of +/-7.68 MHz.
I will suggest updating the UHD version with the newest one as well as the Ubuntu with the 18.04 LTS version if it is possible.
The alternative API could be Python API.
Hope this was helpful.
