03-25-2019 08:49 AM
I'm using a USRP 2920, and I would like to get the chirp spread spectrum of a LoRa Emitter (868MHz).
I have been looking for the examples with the USRP toolkit, but i didn't find one wich could get the sprectrum.
See the attached image, to understand what I need ....
PS : with the VI "niUSRP EX Spectral Monitoring (History).vi" I can get the sprectrum (Amplitude vs frequency), but what I need is frequency vs time
Thanks !
David
03-25-2019 07:17 PM
Hi David,
To measure the frequency vs time spectrum, you can use the STFT function in LabVIEW.
You can search the function on block diagram:
Signal processing --> Spectral --> STFT spectograms.vi
Also, you can find out how to use it from some LabVIEW examples. Please try to search examples by STFT keywords on NI Example Finder.
Thanks.
03-26-2019 02:33 PM
Hi Chan82,
Thanks for your answer ! I have found an example with STFT (STFT spectrogram demo.vi), but now the difficulty will be to get datas from the USRP, and to use this function so I could see the specific chirp modulation ....
David
06-19-2024 04:32 AM
Is it possible to interface lora using LabVIEW?
