USRP Software Radio
Niusrp.dll question
I have a *very* large legacy program that runs under Windows and was developed using NI's LabWindows.
The NI-USRP device looks very interesting to an application my company is considering.  I've seen the few
discussions in this forum regarding using the niusrp.dll with a MSVC compiler, but those discussions were
from a couple of years ago.  I've looked at the information on the Ettus web site regarding using the UHD driver,
but that looks like there would be a large learning curve coming from the Windows/LabWindows world.  The big question is, can I
hook into the niusrp.dll from LabWindows (using 'C', not C++)?  That would be the most cost effective for us.
Just trying to find out what's possible at this point.  Does anyone have any thoughts on this?
Thanks!
(5,732 Views)
The officially supported language and ADE for the NI-USRP driver is LabVIEW. However, someone had a similar question on the forms, but about C# or .net C++, which requires one to write a wrapper DDL to access the driver. Since you want to use the C language, it will be pretty straight forward. You can simply call into the driver using the niusrp.h file found in the following directory: C:\Program Files\National Instruments\NI-USRP\includes.
Matthew R.
Field Applications & Systems Engineer
(5,706 Views)
Matthew,
I just downloaded the NI-USRP driver and had a look at the .h files..  EASY!!!
Thanks so much for your help!
(5,699 Views)
No problem, anytime, good luck with your application! Cheers!
Matthew R.
(5,686 Views)
