USRP Software Radio
USRP-2943 can not connected to PC via ethernet
Hello everyone
I try to connect the USRP-2943 to PC via ethernet cable, but my PC can not recognize it.
I use a SFP+ to ethernet converter at the port 0 of USRP-2943, and connect a CAT6 ethernet cable between the converter and my PC.  I set the IP of my PC as 192.168.10.1.
When i power on  USRP, I can not see the USRP-2943 device on "NI-USRP Configuration Utiliy".  But I can ping the device without any problem.
I install the latest NI-USRP driver but it does not work.
And accroding to https://forums.ni.com/t5/USRP-Software-Radio/Problem-in-conection-between-usrp-2943R-and-laptop-usin... ,
I update the bitfile using PCIe/PXIe connection, unfortunately it still does not work.
(1,729 Views)
Accepted by topic author Heart7
Done.
the netcard driver of laptop should be set as 1Gbps full duplex
(1,609 Views)
