05-21-2019 06:58 AM - edited 05-21-2019 07:04 AM
I'm a rookie,and i trying to make a single wave TX,as the pic I attached.
i dont know why the loop of TX data is success only when first loop but second loop start being wrong?and I got error code -1074118645.
can anyone please guide through this problem?
05-21-2019 08:27 PM
It occurs when the first code execution is forcibly terminated rather than a normal termination. I guess it was because the FPGA settings were twisted after that. To solve this problem, press the stop button on the front panel, not on a forced shutdown in the execution menu bar.
05-22-2019 07:00 AM
Thank you for answer my question,
but what I actually want to ask is how to make this being none-stopped loop,not ended in one loop?
is data wrong or the setting?
05-22-2019 07:11 AM
I'm sorry. I misunderstood your question. The error you see is the underflow error. What is the size of the input array in the Tx loop? It seems to be solved by increasing the size of this array. (y in the cluster)
