USRP Software Radio
USRP Hardware reset
Recently LabVIEW has encountered a problem with not recognizing NI-USRP equipment, and we would like to reset the hardware.
The reason for the reset was not found in LabVIEW itself but in the case of USRP,
it is judged that the problem was caused by frequent changes in firmware and FPGA.
If you know how to reset USRP or if you have any precautions, please reply.
(1,672 Views)
What USRP device are you using?
Best regards
(1,556 Views)
thank you, your reponse.
i'm using NI-USRP2932.
(1,545 Views)
Have you configured your device correct according to the link below?
https://www.ni.com/pdf/manuals/376356b.pdf
If not, please try to reconfigure.
Best regards
(1,539 Views)
