raghav@raghav-XPS:~$ uhd_usrp_probe --args addr=192.168.10.2
[INFO] [UHD] linux; GNU C++ version 7.5.0; Boost_106501; UHD_3.15.0.HEAD-0-gaea0e2de
[INFO] [X300] X300 initialization sequence...
[INFO] [X300] Maximum frame size: 1472 bytes.
[INFO] [X300] Radio 1x clock: 200 MHz
[INFO] [GPS] No GPSDO found
[WARNING] [UDP] The send buffer could not be resized sufficiently.
Target sock buff size: 2426666 bytes.
Actual sock buff size: 1048576 bytes.
See the transport application notes on buffer resizing.
Please run: sudo sysctl -w net.core.wmem_max=2426666
[INFO] [0/DmaFIFO_0] Initializing block control (NOC ID: 0xF1F0D00000000000)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1316 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1315 MB/s)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000001)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000001)
[INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000000)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000000)
[INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000000)
_____________________________________________________
| Device: X-Series Device
| | Mboard: X310
| | revision: 11
| | revision_compat: 7
| | product: 30818
| | mac-addr0: 00:80:2f:31:49:67
| | mac-addr1: 00:80:2f:31:49:68
| | gateway: 192.168.10.1
| | ip-addr0: 192.168.10.2
| | subnet0: 255.255.255.0
| | ip-addr1: 192.168.20.2
| | subnet1: 255.255.255.0
| | ip-addr2: 192.168.30.2
| | subnet2: 255.255.255.0
| | ip-addr3: 192.168.40.2
| | subnet3: 255.255.255.0
| | serial: 31EC216
| | FW Version: 6.0
| | FPGA Version: 36.0
| | FPGA git hash: fde2a94
| | RFNoC capable: Yes
| | Time sources: internal, external, gpsdo
| | Clock sources: internal, external, gpsdo
| | Sensors: ref_locked
| | | RX Dboard: A
| | | ID: UBX-160 v2 (0x007e)
| | | Serial: 31E17CE
| | | | RX Frontend: 0
| | | | Antennas: TX/RX, RX2, CAL
| | | | Sensors: lo_locked
| | | | Freq range: 10.000 to 6000.000 MHz
| | | | Gain range PGA0: 0.0 to 31.5 step 0.5 dB
| | | | Bandwidth range: 160000000.0 to 160000000.0 step 0.0 Hz
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: A
| | | | Gain range digital: 0.0 to 6.0 step 0.5 dB
| | | RX Dboard: B
| | | Serial: 31E17CF
| | | | RX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: B
| | | TX Dboard: A
| | | ID: UBX-160 v2 (0x007d)
| | | Serial: 31E17CE
| | | | TX Frontend: 0
| | | | Antennas: TX/RX, CAL
| | | | Sensors: lo_locked
| | | | Connection Type: QI
| | | | Uses LO offset: No
| | | | TX Codec: A
| | | | Gain Elements: None
| | | TX Dboard: B
| | | Serial: 31E17CF
| | | | TX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type: QI
| | | | Uses LO offset: No
| | | | TX Codec: B
| | | | Gain Elements: None
| | | RFNoC blocks on this device:
| | | * DmaFIFO_0
| | | * Radio_0
| | | * Radio_1
| | | * DDC_0
| | | * DDC_1
| | | * DUC_0
| | | * DUC_1
