07-31-2018 02:17 PM
Thank you for this information. This really helps.
04-01-2019 01:46 AM
Hello Dylan, I want to use NI USRP RIO as X310 with UHD for a small application and then convert it back to NI USRP RIO. I checked this https://kb.ettus.com/Converting_an_X310_into_an_NI-USRP_Rio and noted that "Note there is no method at this time to load DC offset corrections without sending the unit back to the factory."
Is there any update on this? Do I loose DC offset values when converting back to NI USRP RIO?
04-02-2019 10:46 AM
Hi Avinaash,
There still isn't a method to load DC offset corrections without sending the unit back to the factory. You will lose the DC offset values when converting back to NI USRP-RIO.
