This test returns a failure for any Boolean controls that match a user-specified mechanical action setting:
The test also has an option to change the detected setting to a new one:
Make sure you backup your code before running this VI Analyzer test if you select this configuration option.
This test is saved in LabVIEW 2015. Follow the instructions here to install and use this test.
