The Image Display control (IMAQ Image.ctl) allows the user to change the color palette.
Like for the Intensity Chart and Graph objects in LabVIEW, it would be useful to add a color scale object to the control in order for the user to be able to visualize the color <-> value correspondance.
Like for the Intensity Chart and Graph objects in LabVIEW, the color scale should also allow the user to set the display range (min and max value) as well as the out of range color values.
