Vision Idea Exchange
MS_MM
Particle Analysis Input Image Type
Status: New
Supporting only binary images as input type for the particle analysis is reducing the use cases where this functionality can be used. In many segemtation methods, e.g. superpixel segmentation or watershed segementation, the segmentation result is a labeled image. Being able to perform particle analysis on labeled images would enhance the modularity of this function. Since the particle analysis in internally performing probably a labeling anyway, and in many cases, the label of an object which is to be analysed is known too, it could also reduce the computational cost of this function.
