About the use of hx711 through myrio
From this article已解决: Interfacing myRIO with HX711 Load Cell - NI Community, I found the hx711 program based on myrio, but I encountered problems after running it
First, I made the following changes to the program (I used the functions in the myrio Toolkit)
The values obtained after the operation are all - 1. Can anyone tell me where the problem is? Thank you very much for your help. The program operation results are as follows:
(1,756 Views)
Duplicate/related posts
https://forums.ni.com/t5/Academic-Hardware-Products-myDAQ/SPI-myrio/m-p/4251033
https://forums.ni.com/t5/Academic-Hardware-Products-myDAQ/About-the-use-of-hx711-through-myrio/m-p/4...
BTW - you should not be posting under Examples, those are properly developed code to be shared as example and not to post your questions
https://forums.ni.com/t5/Example-Code/HX711-myrio/ta-p/4250985
Santhosh
Soliton Technologies
(1,733 Views)
