04-29-2021 02:55 AM
I was running my program with myRIO, but I noticed that myRIO was disconnected with my pc after half hour. Then it was connected no longer, even if I unplugged its usb and power supply. If I try to run the "Getting Started with NI myRIO wizard", and the attached file is what it shows.
04-30-2021 01:36 AM
What is the state of the status LED indicator?
Regards.
05-15-2021 04:44 PM
What does your program do? Are you doing any File I/O? Can you attach the (I assume LabVIEW) program that you were running?
What does your program do? To what devices is your myRIO connected?
When programs or computers stop working, it is almost always a "hardware" problem or a "software" problem. Without knowing more about your hardware and software, it is difficult to suggest what to do next.
