12-15-2015 07:28 PM
I have the NI USB-7855R R Series Multifuncrion RIO.
The block diagram can be seen attached. Its literally a sinusoid DDS connected to an FPGA I/O.
If I connect AO1 to my CRO I see a square wave +-10V at 500Hz.
Basically, I am seeing what I want except its a square wave instead of a sinewave.
DDS settings:
-freq 500 Hz (I have tried diff freqs and thge result is always the same)
-full scale (I have tried diff range sizes)
-0 deg Phase offset
-LUT 16k (I have tried diff LUT sizes)
-Amp res 16bit
-Top Level Clock (40Mhz?)
Questions:
1. A person in my lab ran a similar program on their machine. Their 'Connector1 AO0' icon was blue (I16 format) where as mine is grey. Could that be relevant at all to my issues?
2. How do I view the Analog output settings? I can only find Input settings. Could this be a slew rate or DAC speed issue?
Any other tips/help is appreciated.
12-16-2015 02:53 PM - last edited on 01-04-2024 04:43 PM by migration-bot
Hi meeeeeeh
Did you mean to say that it is connected to a cRIO, or do you actually have a piece of hardware called a CRO? Also, if you are using a cRIO, what module and chassis are you using? I just want to verify that you are using an Analog In module and determine whether the issue could potentially be with the cRIO.
To answer your other questions:
1. The color indicates that the value is "calibrated" instead of "raw". This is probably the source of the issue, since the value is most likely a fixed-point value of 1-bit precision. You will more than likely want to change this value to raw. Here is a tutorial explaining the difference between calibrated and uncalibrated data on the NI R Series for USB.
2. I don't know of any way to edit analog out values for your NI USB-7855-R, but if the problem persists, I will look into this.
Let me know if this information is helpful or if you run into any other problems!
12-16-2015 05:47 PM
Okay thanks for your help.
Turns out it expected 20 / 5 bit formatted fixed point (15 frac, 5 exp bits), where as I thought it would want I16 but didn't know about the raw/calibrated.
All good, I fixed it up and a sinusoid is appearing 8-)
Cheers again!
