Error -2147220324
Hello, When I try to install myRIO ("NI myRIO USB Monitor" / "Launch the Getting Started Wizard"), I get this error and it says that a file transfer error (FTP or WebDAV) occurred,
also myRIO Status LED is blinking twice every few seconds.
Win 7
64Bit
(6,186 Views)
Accepted by sb_ntb
Hi sb_ntb,
I think this could fix your problem:
Why Am I Getting Error -2147220324 When Trying to Install Software on a myRIO?
http://digital.ni.com/public.nsf/allkb/81BBF63EFD85F43286257D8F00450C7D
I know it mostly happens with Win 8.1 but maybe it's the same issue on win7
Hope it helps you 😉
(6,169 Views)
Also the LED flashing twice indicates this: (Page 13 of the RIO specs)
The device has detected an error in its software.
This usually occurs when an attempt to upgrade the software is interrupted.
Reinstall software on the device
(6,166 Views)
我出现的问题是360杀毒软件把RT images里的所有.err文件删掉了,在NI MAX里安装,出现提示里缺少的文件,找装好的电脑里找缺少的文件,复制过来,就解决了
(5,476 Views)
我出现的问题是360杀毒软件把RT images里的所有.err文件删掉了,通过NI MAX远程系统给终端装软件时,根据提示缺少的文件,在已装好的电脑里找需要的的文件,复制过来,就解决了
(5,474 Views)
