09-06-2015 05:44 AM
I have tried to connect a 2D array to an NSV. However, there is an issue connecting a 2D array to a 1D NSV. So, how can I change the property of the NSV from 1D to 2D, instead of inserting the functions either BUILD ARRAY for INDEX? Thanks in advance!
09-06-2015 06:59 PM
Sorry, my question should be how to connect a 1D array to a 2D networked-shared-variable without having to either insert functions of BUILD ARRAY or INDEX between them. To be exact, how can I change the property of a 1D variable to 2D? I cannot seem to find it out.
09-07-2015 04:10 AM - edited 09-07-2015 04:11 AM
Build Array. You can change the property of a 1D Array to 2D.
In addition, you can try to chang the type of Networke Shared Variable.
09-07-2015 08:59 AM
Thanks for your answer,Klaus000.
However, what if I don't want to change the property of a 2D array to 1D? Under this circumstance, how can I change the type of NSV? I cannot seem to find out a 2D NSV. Should I have to create it and how? Thanks again!
09-09-2015 09:35 AM
About your question, Please make sure you have he Network Variable API. You can follow this link.
http://forums.ni.com/t5/LabWindows-CVI/Network-Shared-Variable-read-string-with-CVI/m-p/3086581
09-09-2015 06:31 PM
Hi, I have solved the problem myself before your answers. Thanks all the same!
