Issues with Parallel inductance distortion
I'm having some problems using the myDAQ function generator. Placing a 1mH inductor in parallel with the function generator distorts the output a lot.
Does anyone have a solution to this problem?
Without inductor:
With inductor in parallel:
(2,645 Views)
If you put a 1mH in parallel (not in series), well read the spec of your myDAQ (output impedance and max output current)
calculate the complex load you apply with your 1 mH @ 100 Hz (you can measure additional parameters of your inductivity or look them up in the datasheet, since a more realistic model of your REAL component contains some more parameters 😉 )
What you migth see in your second measurement ..  What happens with an DAC output while abused .. it migth produce high frequency current artifacts that run into your inductivity ...    How was the formular for inductivities,current and voltage?
Greetings from Germany
Henrik
LV since v3.1
(2,607 Views)
I had a short look into the myDAQ spec...  max output current seems to be 2mA.
What do want to do?
Henrik
LV since v3.1
(2,602 Views)
Hi, thanks for your response.
I  want to build a band pass filter but when I add the inductor, the output distorts. I have added a 470Ω resistor before connecting the inductor which has removed the distortion but i'm still not sure about why it occurs.
Thank you!
(2,595 Views)
