MyDAQ ADC Characterization
I am trying to generate a ramp from 0 to 10 volts using the Analog Output, and then read those voltages on an Analog Input channel on the MyDAQ. I set the Analog Input to read ~3 million samples, with a sampling frequency of 100KHz. The expected result of my program is a histogram with 65536 bins, with 50 hits per bin. The problem I am having is that approximately every other bin has 0 hits, and the remainder are ~100 hits, which does average out to 50 hits/bin, but I need all the bins to have ~50 hits.
My main question is: would there be any issue with connecting the Analog Output of the MyDAQ to the Analog Input?
No matter what adjustments I make, including setting the Analog Output ramp to update at twice the frequency that the Analog Input takes samples, I consistently get the same results of approximately every other bin having 0 hits.
Any help or insight would be greatly appreciated, thank you.
Message 1 of 15
(7,048 Views)
Can please upload your code or some screeshots to be able to see the application? That way we can understand in a better way.
Randy @Rscd27@
Message 2 of 15
(7,031 Views)
Here is a picture of the hardware setup, and one of the vi's used. The main vi is too large so I will screenshot it.
hardware
Message 3 of 15
(7,020 Views)
Here is the main vi screenshot.
Message 4 of 15
(7,019 Views)
Hello Kev,
Thanks fo the answer, can you please send me the vi. Since you are using DAQ Assitant i cannot see the configuration of it.
Randy @Rscd27@
Message 5 of 15
(7,014 Views)
Thank you for your replies, can you PM me your email so I can send the VI?
Message 6 of 15
(7,009 Views)
You upload the code here. Just as the screenshot
Randy @Rscd27@
Message 7 of 15
(6,995 Views)
The VI is a little to big to upload, even compressed. I've uploaded it to dropbox, here is the link.
https://www.dropbox.com/s/6gjjn18rnwkvabi/adc3%20-%20Copy.vi?dl=0
Message 8 of 15
(6,987 Views)
Hey Kev,
Can you attach the ramp.vi I have a myDAQ here so maybe i can try to run it
Randy @Rscd27@
Message 9 of 15
(6,985 Views)
ramp.vi is attached in the same post as the hardware picture I believe
Message 10 of 15
(6,980 Views)
