To obtain temperature versus time graph
Iam using daq assistant in lab view to measure temperature of thermocouple where iam getting the results in form of amplitude versus time graph instude i want the temperature versus time curve so plzz help me out in finding my desired output
(1,792 Views)
Please explain the problem better.
  • Do you want to change the label of the Y axis from "amplitude" to "temperature"? Have you tried to just rename the axis?
  • Do you have a scaling problem converting voltage to temperature?
(1,752 Views)
Please attach your VI.  It may be something as simple as right-clicking the Chart and changing the X Axis "name" to be "Temperature".  Note that this assumes that the Hardware device you are using reports its values in the appropriate units, such as degrees F or C.  Looking at your code will help us to better understand what you are trying to do, and thus make it clearer how you should go about doing it.
(1,666 Views)
