myDAQ not working after updating Mac OS to High Sierra?
I updated my iMac to the High Sierra OS, and installed the latest NI-DAQmx for myDAQ driver. The driver seemed to install fine, and the system seems to recognize the myDAQ device, indicating that the self-test succeeded. But when I attempt the loopback test, it gives an error indicating that "NI-DAQmx is unable to communicate with the device." (Error -200324)
Any hints as to what is wrong? The same test worked fine some time ago, before I updated the OS.
Message 1 of 13
(6,965 Views)
RLSprouse,
Are these the steps that you followed?
Using the NI myDAQ with Mac OS
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P72ySAC
I noticed that it said the driver isn’t necessarily supported in High Sierra, but it might work.
Message 2 of 13
(6,937 Views)
Yes, this is the procedure I followed. One question: The error message I receive says to make sure the device is not reserved by another driver such as Traditional NI-DAQ (Legacy). How do I determine if the old driver is active, and make sure the old driver is deleted?
Message 3 of 13
(6,914 Views)
RLSprouse,
I found this about how to handle having traditional NI-DAQ (Legacy) and NI-DAQmx:
Can I Use Traditional NI-DAQ (Legacy) and NI-DAQmx at the Same Time?
http://digital.ni.com/public.nsf/allkb/890B0DA164567EAD86257AAE0057E1E2
What are you doing when it gives you that error message?
What does your device look like in NI MAX?
Message 4 of 13
(6,908 Views)
At this point, I can't do anything with the myDAQ under High Sierra. I reinstalled the NI-DAQmx for myDAQ driver, and when I go to the System Preferences panel and click the NI myDAQ icon, I get a window saying "System Preferences quit unexpectedly while using the nipalu plug-in.
Yesterday I was able to get things working running Windows 8.1 under Parallels. But that's not the way I want to work. I wish you folks would dedicate a little more resource on Mac support.
Thanks for your consideration.
Message 5 of 13
(6,884 Views)
I am also desperately trying to get myDAQ working on a mac with the High Sierra OS. Is there any progress with this topic?
Message 6 of 13
(6,864 Views)
Can anyone from NI comment on the possibility of updating myDaq drivers for osx?
Message 7 of 13
(6,756 Views)
See this article: Installing NI Driver on MacOS High Sierra Causes Kernel Panic
From <https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MguSAE>
Message 8 of 13
(6,407 Views)
Any news on this?
I am running OS X 10.13.4 and my myDAQ is not being detected by the utility tool:
My installation procedure was as follows:
1. Install LabVIEW
2. Install NI-DAQmx for myDAQ
After this, clicking the NI myDAQ utility in System Preferences caused the System Preferences program to crash.
3. Install ni daqmx base
After this, I was able to open the NI myDAQ utility in System Preferences, however the device isn't being detected
4. Install NI-DAQmx for myDAQ again
Same as before, no progress
Any help would be appreciated.
Cheers
Message 9 of 13
(5,858 Views)
Hi zceejkr,
Unfortunately, NI-DAQmx is only supported on Mac OS X v10.9.x (x86_64) and v10.10.x (x86_64). What you could do is try using a computer with one of these versions of Mac OS or try using a computer running Windows.
I hope this helps,
Marti
Marti H.
ELP Engineer
Message 10 of 13
(5,838 Views)
