08-27-2014 09:21 AM
Is there a way to measure current with the myRIO platform?
08-28-2014 04:54 AM
Hi Zillion,
There is no input on NI myRIO to measure current but you can easy measure current with a Shunt Resistor or a Hall-Effect-Based Linear Current Sensor IC.
You get a Shunt Resistor in every electronic shop. If you are looking for a Hall-Effect-Bassed Current Sensor you can use e.g. ACS712 from Allegro. Especially for high current measurement I would prefer the Hall-Effect Bassed Current Sensor. If search in web for ACS712 you find a lot of ready to use boards with the AC712 IC.
Best Regads,
Wolfgang
08-28-2014 11:00 AM
08-28-2014 12:41 PM
I have the ACS758 by Allegro, but can't find a calibration equation for it and don't have the equipment to provide a constant variable current for my own calibration. The link that you provided for measuring current with a shunt resistor looks very helpful! Thank you!
08-28-2014 03:06 PM
Are there recommended values for RL and Rs?
08-29-2014 03:27 AM
For ACS758 you find the Sensitivity (mV/A) auf page 2 in http://www.allegromicro.com/~/media/Files/Datasheets/ACS758-Datasheet.ashx.
RL is the Load resistance of your device (for example a motor).
RS is the Shunt resistance. RS depends on the current range you want to measure.
R = U / I
Assumed you want 1 V for the highest current value and the highest expected current value is 2 A than you should use a resistor of 0.5 Ohm.
