08-26-2022 01:33 PM
How can I wire a Panasonic EX-14A proximity sensor to a myrio?
08-29-2022 10:30 AM
you may wire as presented on page 7 of the datasheet https://www.farnell.com/datasheets/1784477.pdf
The myrio is the LOAD in this circuit
just a heads up: this sensor is 12VDC to 24VDC, your myrio is not. you need a driver to help you with that. If you need fast response, look for a transistor, if it requires fast switch, look for a fast switching transistor, if your application is slow, and does not switch very often, then a interface relay may also work.
